주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Door Sensor Replacement
필요한 것
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 1 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 1 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 1 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 2 단계, 이미지 3개 중 3개
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: 3 단계, 이미지 2개 중 2개
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: 4 단계, 이미지 2개 중 2개
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 30
지난 30일: 121
전체 시간: 4,199
