주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Evaporator Fan Replacement
필요한 것
  1. Whirlpool Refrigerator Evaporator Fan Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: 3 단계, 이미지 2개 중 2개
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Evaporator Fan Replacement: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 3개
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 3개
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: 7 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: 7 단계, 이미지 2개 중 2개
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire(s) attached to the evaporator fan.
  8. Whirlpool Refrigerator Evaporator Fan Replacement: 8 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement: 8 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the evaporator fan.
  9. Whirlpool Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan: 9 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the evaporator fan.
  10. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 10 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 10 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 10 단계, 이미지 3개 중 3개
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure any remaining foam buffers.
  11. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 11 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 11 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 11 단계, 이미지 3개 중 3개
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: 12 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: 12 단계, 이미지 2개 중 2개
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 13 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 13 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 13 단계, 이미지 3개 중 3개
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 14 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 14 단계, 이미지 2개 중 2개
    • Remove the motor bracket.
  15. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 15 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 15 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 15 단계, 이미지 3개 중 3개
    • Pull the motor straight out of its housing to remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
2가이드 댓글
Fridge howls a couple times a day for about 10 minutes then noise slowly goes down and away. Howling stops if I open door, returns once closed. Fridge/freezer keeps working and stays cold??????
ROBERT - 답글
Yep, mine did the same quite some time ago. Finally the evaporator fan gave up so the freezer, towards the bottom (double door unit) would freeze water but not the upper section. The evaporator fan pushes air from the freezer through some ducting over to the refrigerator which is how the fridge stays cold. On my Whirlpool I removed a panel which gave me access to reach in and feel the fan, noticing it was not turning. With a little help from WD 40 the fan started spinning but later stopped. As soon as I did get the fan working the entire freezer measured the right temperature for freezing as did the fridge, the fridge temp went down and finally measured "safe" on my temp guage. NOW it's time to replace that fan WHICH is much cheaper that replacing the entire refrigerator.
Hope this helps give you an idea what that noise you're hearing might be and pointing to the fan which may finally give up the ghost.
Lucky Lane - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 50
지난 30일: 230
전체 시간: 10,865
