주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement
필요한 것
  1. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2개 중 2개
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 3개
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Unfasten the control board: 4 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement: 5 단계, 이미지 3개 중 3개
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 3개
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Fingerprint-Resistant Black - WRS588FIHV Control Board Replacement, Remove the control board: 7 단계, 이미지 1개 중 1개
    • Remove the control board.
결론
Matt Zieminski
회원 가입일: 02/23/15
48,354 평판
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 62
