주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Freezer Thermistor Replacement
필요한 것
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: 3 단계, 이미지 2개 중 2개
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 5 단계, 이미지 3개 중 3개
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 6 단계, 이미지 3개 중 3개
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 7 단계, 이미지 3개 중 3개
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: 8 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: 8 단계, 이미지 2개 중 2개
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: 9 단계, 이미지 1개 중 1개
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: 10 단계, 이미지 1개 중 1개
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
1가이드 댓글
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 107
전체 시간: 3,878
