주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Icemaker Assembly Replacement
필요한 것
  1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: 3 단계, 이미지 2개 중 2개
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: 4 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: 5 단계, 이미지 3개 중 3개
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: 6 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: 7 단계, 이미지 1개 중 1개
    • Remove the icemaker assembly.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 39
지난 30일: 207
전체 시간: 7,659
