소개
Use this guide to replace the motor thermal protector and start relay combo assembly on your older Whirlpool side‑by‑side refrigerator .
This assembly combines the start relay, which energizes the motor start winding temporarily to allow the motor to start. The thermal protector protects the motor from excessive current. This current would cause the motor to overheat and ultimately fail.
When this device fails, the compressor will not start. If the start relay sticks, it can cause the starting winding to be energized continuously, which will lead to failure. If the thermal protector isn't functioning, the motor can be burned out.
This guide is based on a Whirlpool Model ED5FTGXKQ02 Refrigerator.
필요한 것
Lift the bottom edge of the condenser cover away from the refrigerator.
Pull down on the condenser cover to free it from the retaining tabs at the top edge and remove it.
Cut any cable ties securing the thermal protector and start relay to the compressor.
Use long nose pliers to pull and disconnect the ground wire from the compressor.
Pull the thermal protector and start relay assembly straight off the compressor to disconnect it.
Pull straight back on the spade connectors with long nose pliers to disconnect the wires.
Repair didn’t go as planned? Ask our Answers community for help.
