주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Temperature Control Board Replacement
필요한 것
  1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 2 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: 3 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: 3 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 4 단계, 이미지 3개 중 3개
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 5 단계, 이미지 3개 중 3개
    • Disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: 6 단계, 이미지 1개 중 1개
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 7 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: 8 단계, 이미지 1개 중 1개
    • Pull the temperature control board straight out of its housing to remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
1다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 43
전체 시간: 1,939
