주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Water Filter Replacement
필요한 것
  1. Whirlpool Refrigerator Water Filter Replacement, Open the doors: 1 단계, 이미지 1/3 Whirlpool Refrigerator Water Filter Replacement, Open the doors: 1 단계, 이미지 2/3 Whirlpool Refrigerator Water Filter Replacement, Open the doors: 1 단계, 이미지 3/3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Water Filter Replacement, Water Filter: 2 단계, 이미지 1/3 Whirlpool Refrigerator Water Filter Replacement, Water Filter: 2 단계, 이미지 2/3 Whirlpool Refrigerator Water Filter Replacement, Water Filter: 2 단계, 이미지 3/3
    • Pull the water filter door in the base grill open.
  3. Whirlpool Refrigerator Water Filter Replacement: 3 단계, 이미지 1/3 Whirlpool Refrigerator Water Filter Replacement: 3 단계, 이미지 2/3 Whirlpool Refrigerator Water Filter Replacement: 3 단계, 이미지 3/3
    • As the door opens, the filter gets ejected out.
    • When the filter is fully ejected, pull the filter out.
    • A towel is suggested as water might spill while pulling the old filter out.
  4. Whirlpool Refrigerator Water Filter Replacement: 4 단계, 이미지 1/2 Whirlpool Refrigerator Water Filter Replacement: 4 단계, 이미지 2/2
    • Get the new filter out of its packaging.
    • Remove the covers from the filter inlets. Make sure the O-rings stay on the filter.
  5. Whirlpool Refrigerator Water Filter Replacement: 5 단계, 이미지 1/2 Whirlpool Refrigerator Water Filter Replacement: 5 단계, 이미지 2/2
    • Align the new filter with the filter housing and insert filter into place.
    • The arrows should be facing the same way.
  6. Whirlpool Refrigerator Water Filter Replacement: 6 단계, 이미지 1/3 Whirlpool Refrigerator Water Filter Replacement: 6 단계, 이미지 2/3 Whirlpool Refrigerator Water Filter Replacement: 6 단계, 이미지 3/3
    • Close the filter cover door completely to snap the filter into to place correctly. You will hear a snap!
  7. Whirlpool Refrigerator Water Filter Replacement, Flush the water system: 7 단계, 이미지 1/2 Whirlpool Refrigerator Water Filter Replacement, Flush the water system: 7 단계, 이미지 2/2
    • Flush the water system by holding the water dispenser for 5 seconds and releasing for 5 seconds repeating this step until water begins to flow.
    • After water flowing, get at least a total of 3 gallons dispensed in order to see full flushed water results.
  8. Whirlpool Refrigerator Water Filter Replacement: 8 단계, 이미지 1/3 Whirlpool Refrigerator Water Filter Replacement: 8 단계, 이미지 2/3 Whirlpool Refrigerator Water Filter Replacement: 8 단계, 이미지 3/3
    • You may need to reset the filter indicator by pushing the switch 5 times in a row.
    • When the filter indicator is reset, the light should change from red to green.
결론
After flushing the water system completely, get ready to have some refreshing water with a cup of ice freshly made with the new installed water filter.
다른 한 분이 해당 안내서를 완성하였습니다.
brenda lopez
회원 가입일: 10/05/21
366 평판
안내서 2개 작성하였습니다
CSU Los Angeles, Team 11-30, Grodsky Fall 2021 CSU Los Angeles, Team 11-30, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G30
1 회원
안내서 3개 작성하였습니다
댓글 6개
Changed filter but now water is not coming out of the dispenser. Installed filter correctly per pictures. What could be the problem?
SewFrau58 - 답글
You will have air in the system after changing the filter. Make sure you did turn the water on. Run the water dispenser until water pushes the air out. Run the water until it clears.
Fredric - 답글
Opened the filter door but the filter did not eject. Any troubleshooting advice on how to remove the filter?
Ariana Vega - 답글
You'll want to rotate the filter counterclockwise until it pops out.
nicO -
Filter door will not open all the way.
cjw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 119
30일 전: 610
전체 시간: 13,285
