주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator Water Inlet Valve Replacement
필요한 것
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 4 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 4 단계, 이미지 2개 중 2개
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 5 단계, 이미지 3개 중 3개
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: 6 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 7 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 7 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 7 단계, 이미지 3개 중 3개
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: 8 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement: 8 단계, 이미지 2개 중 2개
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 9 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 9 단계, 이미지 2개 중 2개
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: 10 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement: 10 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Water Inlet Valve Replacement: 10 단계, 이미지 3개 중 3개
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 11 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 11 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 11 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: 12 단계, 이미지 1개 중 1개
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: 13 단계, 이미지 1개 중 1개
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 95
지난 30일: 396
전체 시간: 11,867
