주요 콘텐츠로 건너뛰기
Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement
필요한 것
  1. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Safety precautions: 1 단계, 이미지 1/1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 1/2 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2/2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 1/3 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 2/3 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3/3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Unfasten the control board: 4 단계, 이미지 1/1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement: 5 단계, 이미지 1/3 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement: 5 단계, 이미지 2/3 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement: 5 단계, 이미지 3/3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Disconnect the control board: 6 단계, 이미지 1/3 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Disconnect the control board: 6 단계, 이미지 2/3 Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3/3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator White - WRS588FIHW Control Board Replacement, Remove the control board: 7 단계, 이미지 1/1
    • Remove the control board.
결론
Matt Zieminski
회원 가입일: 02/23/15
38,431 평판
안내서 13개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 17,685개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 5
