주요 콘텐츠로 건너뛰기
Whirlpool WED87HED Dryer Control Panel Replacement
필요한 것
  1. Whirlpool WED87HED Dryer Control Panel Replacement, Safety Precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Control Panel Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Control Panel Replacement: 4 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Control Panel Replacement, Disconnect the control panel: 5 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Disconnect the control panel: 5 단계, 이미지 2개 중 2개
    • Disconnect the control panel cable from the main board.
  6. Whirlpool WED87HED Dryer Control Panel Replacement: 6 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the drum light connector.
  7. Whirlpool WED87HED Dryer Control Panel Replacement, Unfasten the control panel: 7 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Unfasten the control panel: 7 단계, 이미지 2개 중 2개
    • Use a 1/4 inch nut driver to remove the two 16.3 mm‑long sheet metal screws located at each end of the control panel.
  8. Whirlpool WED87HED Dryer Control Panel Replacement, Remove the control panel: 8 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the control panel: 8 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the control panel: 8 단계, 이미지 3개 중 3개
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool WED87HED Dryer Control Panel Replacement, Remove the wiring harness: 9 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the wiring harness: 9 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the wiring harness: 9 단계, 이미지 3개 중 3개
    • Disconnect the wiring harness connectors.
    • Lay the control panel down on a towel or other soft surface to perform the next few steps.
  10. Whirlpool WED87HED Dryer Control Panel Replacement, Unfasten the control board: 10 단계, 이미지 1개 중 1개
    • Use a 1/4 inch nut driver to remove the six 21.4 mm‑long screws which secure the front control board to its housing.
  11. Whirlpool WED87HED Dryer Control Panel Replacement, Remove the control panel unit: 11 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the control panel unit: 11 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Control Panel Replacement, Remove the control panel unit: 11 단계, 이미지 3개 중 3개
    • Lift up the back plate off the control panel and remove it.
    • The control panel is a circuit board attached to a face plate. Replace the entire unit if possible.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
3다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,500 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 706
