주요 콘텐츠로 건너뛰기
Whirlpool WED87HED Dryer Steam Nozzle Replacement
필요한 것
  1. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Safety Precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Steam Nozzle Replacement: 4 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the cover plate: 5 단계, 이미지 1개 중 1개
    • Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
  6. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cover plate: 6 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cover plate: 6 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cover plate: 6 단계, 이미지 3개 중 3개
    • Remove the cover plate.
  7. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the cord: 7 단계, 이미지 1개 중 1개
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    • Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
    • If your plug has 4 prongs, there will be a ground connection from the cord as well. Use a 5/16 inch nut driver to remove this connection.
  8. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cord: 8 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cord: 8 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the cord: 8 단계, 이미지 3개 중 3개
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the cord terminal block: 9 단계, 이미지 1개 중 1개
    • Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
    • Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
  10. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Move the cord terminal block: 10 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Move the cord terminal block: 10 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Move the cord terminal block: 10 단계, 이미지 3개 중 3개
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the rear panel: 11 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the rear panel: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Use a 1/4 inch nut driver to remove the eleven rear panel screws.
    • Ten 20 mm-long screws
    • One 12.9 mm-long screw under the water inlet.
  12. Whirlpool WED87HED Dryer Steam Nozzle Replacement: 12 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement: 12 단계, 이미지 2개 중 2개
    • Use a 1/4 inch nut driver to remove the 16.4 mm-length screw holding the main board bracket to the chassis.
    • Use a 1/4 inch nut driver to remove the two 20 mm-long screws from the top rear of the machine.
  13. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the rear panel: 13 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the rear panel: 13 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the rear panel: 13 단계, 이미지 3개 중 3개
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Reassembly information: 14 단계, 이미지 2개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Reassembly information: 14 단계, 이미지 2개 중 2개
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the water tube: 15 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the water tube: 15 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Disconnect the water tube: 15 단계, 이미지 3개 중 3개
    • Push the retaining clip out with a small screwdriver or spudger.
    • Grab the retaining clip with your fingertips and remove it.
  16. Whirlpool WED87HED Dryer Steam Nozzle Replacement: 16 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement: 16 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement: 16 단계, 이미지 3개 중 3개
    • Press the yellow sleeve toward the valve to release the water tube.
    • While holding the sleeve in place, pull the water tube out of the sleeve
  17. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten the nozzle cover: 17 단계, 이미지 1개 중 1개
    • Use a 1/4 inch nut driver to remove the 12.9 mm‑long sheet metal screw securing the steam nozzle cover.
    • Be careful not to drop any tools as you work, or you may chip the drum's enamel coating
  18. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the nozzle cover: 18 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the nozzle cover: 18 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove the nozzle cover: 18 단계, 이미지 3개 중 3개
    • Lift the lower edge of the cover and tilt it outward to clear the nozzle.
    • Slide the cover down to disengage the tab at the upper end of the cover.
    • Remove the cover.
  19. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Unfasten nozzle assembly: 19 단계, 이미지 1개 중 1개
    • Use a 1/4 inch nut driver to remove the 12.9 mm-long nozzle assembly screw.
  20. Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove nozzle assembly: 20 단계, 이미지 3개 중 1개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove nozzle assembly: 20 단계, 이미지 3개 중 2개 Whirlpool WED87HED Dryer Steam Nozzle Replacement, Remove nozzle assembly: 20 단계, 이미지 3개 중 3개
    • Lift the nozzle assembly up to disengage the tab at the lower end.
    • Remove the nozzle assembly.
결론
Repair didn’t go as planned? Ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,500 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,629개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 160
