주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
Why! NH57ADS CPU Replacement
필요한 것
  1. Why! NH57ADS CPU Replacement, Battery: 1 단계, 이미지 3개 중 1개 Why! NH57ADS CPU Replacement, Battery: 1 단계, 이미지 3개 중 2개 Why! NH57ADS CPU Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery.
    • ...and lift to remove it
  2. Why! NH57ADS CPU Replacement, Bottom Cover: 2 단계, 이미지 3개 중 1개 Why! NH57ADS CPU Replacement, Bottom Cover: 2 단계, 이미지 3개 중 2개 Why! NH57ADS CPU Replacement, Bottom Cover: 2 단계, 이미지 3개 중 3개
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the clips holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS CPU Replacement, Removing the Bottom Cover: 3 단계, 이미지 3개 중 1개 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: 3 단계, 이미지 3개 중 2개 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: 3 단계, 이미지 3개 중 3개
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Slide the bottom cover to remove it.
  4. Why! NH57ADS CPU Replacement, Fan: 4 단계, 이미지 3개 중 1개 Why! NH57ADS CPU Replacement, Fan: 4 단계, 이미지 3개 중 2개 Why! NH57ADS CPU Replacement, Fan: 4 단계, 이미지 3개 중 3개
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: 5 단계, 이미지 3개 중 1개 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: 5 단계, 이미지 3개 중 2개 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: 5 단계, 이미지 3개 중 3개
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
  6. Why! NH57ADS CPU Replacement, CPU: 6 단계, 이미지 3개 중 1개 Why! NH57ADS CPU Replacement, CPU: 6 단계, 이미지 3개 중 2개 Why! NH57ADS CPU Replacement, CPU: 6 단계, 이미지 3개 중 3개
    • Carefully pull the metal bar away from the processor to free it from under the retaining tab, then lift it to release the processor pins.
    • Gently remove the processor by lifting it straight up.
결론
To reassemble your device, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
75%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 359
