주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
Why! NH57ADS Fan and Heatsink Removal
필요한 것
  1. Why! NH57ADS Fan and Heatsink Removal, Battery: 1 단계, 이미지 1/3 Why! NH57ADS Fan and Heatsink Removal, Battery: 1 단계, 이미지 2/3 Why! NH57ADS Fan and Heatsink Removal, Battery: 1 단계, 이미지 3/3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: 2 단계, 이미지 1/3 Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: 2 단계, 이미지 2/3 Why! NH57ADS Fan and Heatsink Removal, Bottom Cover: 2 단계, 이미지 3/3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: 3 단계, 이미지 1/3 Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: 3 단계, 이미지 2/3 Why! NH57ADS Fan and Heatsink Removal, Removing the Bottom Cover: 3 단계, 이미지 3/3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Fan and Heatsink Removal, Fan: 4 단계, 이미지 1/3 Why! NH57ADS Fan and Heatsink Removal, Fan: 4 단계, 이미지 2/3 Why! NH57ADS Fan and Heatsink Removal, Fan: 4 단계, 이미지 3/3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: 5 단계, 이미지 1/3 Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: 5 단계, 이미지 2/3 Why! NH57ADS Fan and Heatsink Removal, Fan and Heatsink Assembly: 5 단계, 이미지 3/3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
결론
To reassemble your device, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
50%
Jerry Wheeler님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Felice Suglia
회원 가입일: 06/15/13
31,100 평판
안내서 264개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 103
