주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
Why! NH57ADS Keyboard Replacement
필요한 것
  1. Why! NH57ADS Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Why! NH57ADS Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Why! NH57ADS Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Keyboard Replacement, Bottom Cover: 2 단계, 이미지 3개 중 1개 Why! NH57ADS Keyboard Replacement, Bottom Cover: 2 단계, 이미지 3개 중 2개 Why! NH57ADS Keyboard Replacement, Bottom Cover: 2 단계, 이미지 3개 중 3개
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Keyboard Replacement, Removing the Bottom Cover: 3 단계, 이미지 3개 중 1개 Why! NH57ADS Keyboard Replacement, Removing the Bottom Cover: 3 단계, 이미지 3개 중 2개 Why! NH57ADS Keyboard Replacement, Removing the Bottom Cover: 3 단계, 이미지 3개 중 3개
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Why! NH57ADS Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Why! NH57ADS Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • Remove the two Phillips screws with the keypad symbol next to them.
    • Insert an opening pick into the upper slot of the keyboard and slide it to the end.
  5. Why! NH57ADS Keyboard Replacement, Remove the Keyboard: 5 단계, 이미지 3개 중 1개 Why! NH57ADS Keyboard Replacement, Remove the Keyboard: 5 단계, 이미지 3개 중 2개 Why! NH57ADS Keyboard Replacement, Remove the Keyboard: 5 단계, 이미지 3개 중 3개
    • Carefully lift the keyboard.
    • Flip up the retaining latch on the black keyboard cable and slide it out of the connector.
    • Repeat with the orange backlight cable.
결론
To reassemble your device, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
50%
Jerry Wheeler님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
31,564 평판
안내서 264개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 151
