소개
查看 iPad Wi-Fi Repair Manual以获得全套维修指南!
昨天,我们抢先发布了一些照片,那时我们可以编写的2197|FCC的测试照片]。但是,请注意:你所看到的是一个预制单元,而这里的照片来自零售版的。
想要跟上硬件世界的步伐吗?点击
我们的
Error
Example:
[Namespace:Which Entity|사람들이 해당 페이지에서 봤으면 하는 내용]
Current text:
[[主题:iPad]]
YouTube[链接| http://www.youtube.com/watch?v=F52osxxZv...|
更新4/5:我们与ChipWorks合作的拆解图片
关注我们的官方微博:iFixit官网资讯
필요한 것
iPad和初代的iPod很想像。
就像大巫见小巫。
把iPad分别和MacBook Pro和戴尔电脑进行比较。
wtf is a dell doing so close to the precious ipad!?
Wes Cook로 부터 인용:
Probably running Flash and taking video with a built in camera, because you know, it can multitask.
I wish there were a "like" option for comments here. I'll just create my own. ^like^
Wes Cook로 부터 인용:
Ha!!!!
이 단계에 사용된 도구:Metal Spudger$2.99
在屏幕和后盖之间插入金属撬棒,将iPad打开。
多么环保的设备啊!
无砷的显示器玻璃
无BFR
无汞的LCD显示器
无PVC
可回收铝和玻璃外壳
保护环境第一!
Is the fron panel easy to remove?
ouimetnick로 부터 인용:
It seems not. In fact the black rubber seal of the edge of the screen has some scratches.
Nobody로 부터 인용:
Lacking naturally occurring metals is not eco-friendly. Human-friendly, but hardly eco-friendly.
Aluminium is a naturally occuring metal. Have a look at your periodic table
Dean Lombard로 부터 인용:
Er... Aluminium is extracted from bauxite which requires enormous amounts of electrical energy to produce. Ghana, to the detriment of its population, has to allocate approximately 70% of its hydro-electricity cheaply to Valco Aluminium smelters.
I don't think that's right. First, the original poster might've meant "naturally-occurring materials" not "metals".
Second, I don't think you'll ever find any metallic (i.e. elemental) aluminium lying about in the environment.
And third, The nominated baddies, PVC, mercury, arsenic, BFR (what is BFR? Do they mean "halocarbons"?) are not "naturally-occurring metal or even naturally-occurring materials". None occurs in nature in that state and PVC sure isn't natural, it's entirely man-mde.
Oh Dean. Aluminum oxidizes readily in nature, and doesn't occur as metallic ore. It is not, in fact, a naturally occurring metal. It is only a naturally occurring oxide.
The periodic table has nothing to say on the matter.
Thanks everyone for correcting my ignorance so politely :)
I was thinking "it's an element" and that was as far as my brain got
Mercury-free LCD display?
I thought it's a LED Backlit Display?
hundehausen로 부터 인용:
It's an LCD display, and it's LED Backlit, for light!
grh로 부터 인용:
BFR means "brominated flame retardants", chemicals electronic components are coated with to protect them from catching fire. They are very toxic and contaminate whole landfills in e-waste.
Paul로 부터 인용:
"ringmuscle" isn't supposed to be the one you think with. It's supposed to hold in your squirts until you can void them in the proper place (not here).
Assuming you're not a troll (which is a foolish assumption on my part, but I give everyone the benefit of the doubt) please see any of a number of good sites: skepticalscience.com is a good one, it's 100% peer-reviewed. It's a convenient list of every vacuous denier argument, along with the proper shredding of same. Bye.
For others that might be interested in this OT digression, volcanoes emit around 0.3 billion tonnes of CO2 per year. This is about 1% of human CO2 emissions which is around 29 billion tonnes per year. More facts here: http://www.skepticalscience.com/volcanoe...
ringmuscle로 부터 인용:
You noob. You probably think CO2 is deadly for the earth and man is the cause of global warming. Typical uniformed human scum... A volcano pumps out more CO2 in 1 blow, than man does all year. 100% fact. Volcanoes go off all the time!
Man is 2% of carbon emissions. Mother nature is 98%
You enjoying sucking those media and Nazi school lessons? You love Al Gore? The guy who wants to globally tax all citizens for breathing?
CO2 is just a part of my concern.
http://en.wikipedia.org/wiki/Global_warm...
During production process, high quantity of water is used. As most of process takes part in China, industrial water aren't filtered before they are released in waterways. Digging the ore for components also makes environmental impact.
http://en.wikipedia.org/wiki/Water_polut...
All this "green product" stuff is marketing. When it comes to environment, yes, I'm some kind of Nazi. It makes my electricity bill small.
Dragan로 부터 인용:
And the CNC machining process consumes even bigger amounts of water and energy than conventional enclosure fabrication methods do. And the working conditions over there in Shenzhen at Focxonn's factories aren't that good as well.
Despite what everyone else is whining about on here no one mentions the fact that at the top portion of the screen in the middle, a little less than a half an inch in is a ribbon cable you need to watch out for. I didn't clip mine but came really close and as old as this thing is I'm not sure I could find a replacement.
将显示组件从后盖中取出。
在屏幕下的第一眼看到两个巨大的锂离子聚合物电池占据了整个后盖的大部分空间。
looks sorta similar to taking apart an iPod touch, just a lot bigger.. that about right, or are the clips somehow fundamentally different than the Touch's?
What is that Y looking connector for? The other cool connector that is the same as the MacBook unibody machenes is for the display, but what about that Y ribbon? What does it do?
Robk732로 부터 인용:
I broke most of my clips taking it apart. Are these clips for sale? It seems the only way to take it apart is to break the clips, then replace them before putting it back together
Why were you taking such a new gadget apart anyways. If it was defective, Apple should cover it... but opening it up kills that warranty.
Robk732로 부터 인용:
They seem like they'd be easy enough to replace with some bent pieces of plastic with a hole made in them. Perhaps the plastic from a DVD case might do the job.
CityZ로 부터 인용:
Yeah I found a metal shop that will make them exact for me, $20 each, or $4 each if I buy 100. So i'll be checking out Home Depot to see what i can rig together.
啊,它掉了。你不知道我们有多高兴,这并不需要热风枪。
善意的提醒:你可能会损坏一些卡扣而使屏幕灭屏。
Are those tabs metal?
How easily they bend?
So the trick is to take off the front without breaking the tabs. We're awaiting the solution. :D
PS Thanks for going through this process for us. Seems something like the bomb-disposal squad. ("What's that noise?...*kaboom*)
Why not just use a big suction cup? It worked perfect on my iPhone.
Ove Celius - 답글
I recently had my iPhone replaced due to a camera defect. While in the Apple Store awaiting the “verdict” I watched the genius inspect every orifice using an otoscope. I assume she was looking for evidence of water damage. Have you been able to identify the materials or surfaces that they inspect on iPhones and now, iPads?
Ove Celius로 부터 인용:
On the iPhone 3G and 3GS, Apple was nice enough to use visible screws instead of tabs. Since the iPad lacks screws and is held together with tabs, I think it's unlikely you could get the iPad apart with a single suction cup. We'll be working on figuring out the least invasive way to get your iPad opened up.
ent399로 부터 인용:
The iPad does feature liquid damage indicators. Apple will deny warranty coverage if these are activated (they turn pink after coming in contact with moisture). There appear to be two of these on the iPad, one in the headphone jack and one near the dock connector.
显示器有一个出厂标记:Honeywell#5280371
它看起来相当松散,主要是因为所有的3G通信模块都没有。
3.75V, 24.8瓦特小时的电池提供持续10小时的使用时间。相比之下,iPhone 3GS有4.51瓦特小时的电池,而MacBook Air有40瓦特小时
USB电源适配器已专门为iPad而增强。由Foxlink技术有限公司生产的10W单元,编号为A1357 W010A051。
The ambient light sensor and its socket to the logic board seems too huge to me. I presume it has enough room for an iSight signals.
Since it has it's own power supply, will it still charge when connected to a USB port on a PC(Or a Mac)?
Thomas J로 부터 인용:
Who manufactured the display?
We don't know who manufactured the display from the unit in this teardown. If anyone knows, we'd love a tip. On another iPad we opened, the LCD markings were different and the panel was clearly manufactured by LG.
Luke Soules로 부터 인용:
The display is Made in Taiwan by Wintek co.,ltd & Sintek co.,ltd.
www.wintek.com.tw
www.sintek.com.tw
Luke Soules로 부터 인용:
I've just read that the panels come from either LG, Samsung or Epson and only the front galss panel with the touch sensors comes from Wintek, but no mention of Sintek.
断开显示数据排线。
移除排线有两步过程。你首先要打开锁定条(如图),然后可以将排线从座子滑出。
显示排线连接方式与所有新的一体化MacBook中使用的样式相同。
That black plastic is to help remove the bar that holds the video connector, but NOT to pull on the connector itself to unplug it - it is not anchored strongly, and I'm surprised it didn't break if you did try it!
主板通过T4 Torx螺丝固定在后盖上。
我们以前从来没有见过苹果用过这么小的螺丝。
wow, that is small for these. the machinery gets bigger, the screws get smaller.
Is iFixit going to carry the T3? how about the glass?
Travis Funk로 부터 인용:
It appears that iPad screws may actually be T4. I used a T3 bit, but others have reported success with a T4 bit. Fortunately, we include both T3 and T4 bits in the 54-piece kit that we already sell. We don't have the iPad glass yet, but we're definitely hoping to offer it in the near future. It looks like at least one person needs a replacement glass already.
逻辑主板的顶部和底部有电磁干扰屏蔽条。
看起来这块板是由AT&S制造的。我们之前没有看到过苹果有这样品牌的PCB制造商。
逻辑主板大约有4.5英寸宽,约占iPad宽度的60%。
The marking is the board manufacturer's UL mark. You should find it on all Apple boards (all everybody's boards), although often it likely to be underneath a component.
The Apple A4 has the cool markings like the marketin photo. The FCC A4 didn't have that. Sadly, it's printed in the wrong direction.
Is Apple using Sandisk iNand chips for flash memory?
They're 64Gbit MLC NAND flash.
In fact you can switch between brands like Toshiba, Micron, etc (We've done this before on 2G and 3G iPhone at iPhoneTECH), and it's possible to upgrade to higher density memories, i.e. 128 Gbit, 256 Gbit and possible to 512 Gbit chips, it means you may upgrade to 128 GB capacity when the memories become available. That would be terrific!
K9 = NAND memory
L = MLC DDP
CG = 64 Gbit
08 = 8x
U = 2.7V~3.6V
1 = Dual nCE & Dual R/nB
M = !st Gen.
Tom Stigler로 부터 인용:
The A4 is likely a multi-die package, with the CPU and DRAM mounted on the same substrate. (High-speed logic and high-density memory require fabrication processes that are less-than-optimal for the other.) That would explain the multiple part numbers. Other folks have pointed out that the K4X2G643GE part number is for a 2Gb (256MB) part.
CityZ로 부터 인용:
Hmm, I also can't seem to account for the small ribbon cable connector that's next to the big double-ribbon connector for the touch-screen.
It's for the headphone jack, seen here.
Sheesh! 2 Gigabits is 512 MB? Since when is a Byte only 4 bits? It's 256 MB of RAM and that goes in line with reports from developers who had their apps rejected for memory warning crashes, which occur at a comparable RAM usage as on the iPhone 3GS.
I wrote about that here: http://www.gaminghorror.net/steffenj/app...
Ok we're looking at two chips here, i get it. 2 Gigabits per chip times two equals 512 MB. But why are developers seeing only the same free amount of memory as on the iPhone 3GS? Why would the iPad keep about 256 MB to itself?
Steffen Itterheim로 부터 인용:
That's what we originally thought, but it turns out there are two 1 Gb chips, for only 256 MB total. Consistent with software reports. Sorry to get your hopes up!
Kyle Wiens - 답글
Kyle Wiens로 부터 인용:
I guess given the software reports, there's no holding out hope that the 2Gb part number refers to each individual DRAM chip inside the A4 rather than the 2 combined?
In any case, can you confirm my interpretation of Samsung's nomenclature that the "64" in K4X2G643GE refers to a 64-bit memory bus width? If that is so, that means that regardless of RAM amount, the iPad has double the memory bandwidth of the iPhone and other smartphones which Anandtech reported to have 32-bit memory buses in their Google Nexus One review. The doubled memory bandwidth would benefit not only the CPU but also the GPU which shares system memory and bandwidth.
It seems A4 is not (yet) revolutionary product, but upgraded version of A8 based processor found in iPhone 3GS.
On FCC RAW data logic board photos of iPad it is clearly seen that the processor, not yet marked as A4 but in old, iPhone style, is manufactured during week 49 of 2009.
In addition, Apple part number of A4, APL0398, is quite similar (upgraded?) to original iPhone 3GS processor PN APL0298.
I was confused about the amount of memory, but the pictures on the Chipworks page cleared that up.
The number in the outside, K4X2G643GE, indicates 2 gigabits (256MB) total, 64 bits wide. The numbers on the inside, K4X1G323PE + K4X1G323PE, indicate 1 gigabit (128 MB) on each die, 32 bits wide.
That's awsome. Is it possible to buy a 128 Gbit MLC NAND flash now?
Cristian Flores로 부터 인용:
K9 = NAND memory
L = MLC DDP
CG = 64 Gbit
08 = 8x
U = 2.7V~3.6V
M = !st Gen.
一个逻辑主板剪掉电磁干扰屏蔽罩的镜头。
这款设备的内存制造商已经从东芝公司换为三星。
三星K9LCG08U1M NAND闪存。
我们喜欢三星的芯片编码容易进行理解。
Broadcom BCM5973的I / O控制器。
苹果A4处理器的外观比昨天FCC的照片要好得多。
德州仪器CD3240A1触摸屏控制器。
NXP: L061 01 4 ZSD950
Also, next to the light-sensor connector at the top, you'll see empty spaces for a tiny 25-pin BGA chip and a 6-pin connector. If I had to hazard a guess as to their purpose, I'd say the chip is camera-related, and perhaps converts the raw camera output to USB, and the 6-pin connector brings out the USB input for testing.
CityZ로 부터 인용:
...and perhaps converts the raw camera output to USB, and the 6-pin connector brings out the USB input for testing.
Can anyone measure the pad pitch of the BGA? If it's 0.50mm, it would fit the SMSC USB3311 or another in-family. The 24-pin connector there would support the 12 signals for ULPI to a camera.
If I had to guess, I'd say that the NXP part is a CBTL06141EE display mux/demux. Oddly it's the only part in the series to have a datasheet marked as confidential.
Well, i read somewhere that the Apple A4 chip contains the Processor, Memory Controller and the Graphics. (I am not sure)
If so, it will generate more heat. But, where is the HEAT SINK for it...? So, does the iPad will have a shorter life because of no heat sink...?
A friend of mine remarked to me: "First thing I thought of when I saw the iPad was that it seemed like a nice alarm clock.
Well, I take it back. IT HAS NO F-ING CLOCK BUILTIN!
http://www.guardian.co.uk/technology/201...
It cannot wake from sleep on an internal alarm. Apparently it cannot
run an alarm clock in background!"
I couldn't believe that - what, no permanently running RTC? To save parts costing under a dollar, they made a big expensive computing device that doesn't know the time and date?
But now I'm looking at that main board more closely, hmmm.... I don't see any 32768Hz crystal. You know the ones - a tiny metal cylinder with two leads, as found in every watch, cheap desk clock, and computing device that, you know, CAN tell the time.
Just possibly the crystal could be in a small rectangular ceramic case, but I don't see any candidates for that either.
This is completely ... beyond absurd. Bizarre. What were they thinking? It really makes me wonder...
With Steve Jobs being on death's door and all, I wonder if he's maybe doing a big 'fu*k youse all' farewell gesture? And the iPad (feminine hygiene name _intended_) is the raised finger?
In six months, all iPads brick themselves, with a permanent, unremovable goatse image. Signed "So long suckers! Thanks for all the cash. S Jobs" And then a deliberate internal short circuit makes the battery explode.
Fortunately, that worry can't be real. Since the iPad doesn't know the date. Err... unless it's online, I suppose.
TerraHertz - 답글
逻辑主板背面观。
弧形边缘上的金条很有可能帮助主板和铝制后壳契合。
Apple 标号:820-2740-A.
苹果标IC的编号是:338S0805
It seems the copyright for that board is 2010. It also seems the logic board manufacture has printed their brand. Even on a production board.
How much RAM does it have? That is the burning question for me. Without a swap file a machine with fixed ram will crash a lot if it doesn't have breathing room. 1st gen iPod touches where under-rammed and can't run a lot of software as well as later models. With such a huge screen you gotta have enough ram. 512MB is what i predict, apple is notorious for using as little as possible to save money.
Abit로 부터 인용:
Can you snap a pix of each button assembly inside the device? It looks like some of the assemblies are glued to the aluminum housing like the original iPhone. Is this the case?
The original iPhone had buttons such as the sleep/wake, volume up and down, and the silent/ringer switch were all held on to the aluminum back with screws.
ouimetnick로 부터 인용:
The original iPhone's back was a stamped aluminum case plus a glued-on cast metal frame, along with a tack-welded metal screw bracket. The buttons and other pieces screwed into the frame that was glued onto the back. The main problem with this was that all the Chinese replacement parts makers advertising on Ebay were selling the plain back case without the frame and other parts necessary to use it. Also, sometimes the frame would become partially unglued from the back when you opened the phone.
The iPad should not have these issues, as the back is a solid hunk of aluminum (though it does have some tack-welded screw mounts). I do foresee iFixit and others selling lots of replacement screen clips that hold the unit together, though.
which brand is it using for its capacititive touch screen?
ekbart van der klunk로 부터 인용:
And yet, they still charge as much as possible. (Sorry, I'm a PC guy, though I don't despise Apple - I have an iPod Touch. I just don't agree with all of their business practices.)
John Smith - 답글
This a Dual Battery switching charger for two battery similar to LTC1760
拆掉把尾插排线固定在后盖上的单颗螺丝。
这条排线明显缺乏与射频天线以及GPS相关的东西。对比FCC的iPad拆解看看GPS在3G版的什么位置。
802.11n WiFi/蓝牙卡集成到尾插排线上。
躲在下方芯片:
Broadcom BCM4329XKUBG 802.11n WiFi +蓝牙2.1 + EDR和FM。
I wish Apple would enable FM reception, or a least broadcasting to a local (car) radio. Anyone know of an iPhone hack?
amiller770 - 답글
That 'capacitor' looks like it is more likely an SMD ferrite monolithic inductor.
Do you know if the solder is tin/lead, or some dreaded rohs high melting point solder?
TerraHertz - 답글
TerraHertz로 부터 인용:
Edit: Ah, the answer to that is obvious from the center pic. You had to heat the metal case with a blowtorch to unsolder it. So, ROHS solder. Which cannot be resoldered without destroying parts. Sigh...
As if bismuth was any better in landfills than lead.
TerraHertz - 답글
amiller770로 부터 인용:
There is no hardware to support FM transmission (only receive) and just because the Broadcom chip has an FM demodulator, doesn't mean that you have enough hardware to support FM reception. You need a substantial set of antenna tuning components, not to mention the antenna itself. Those pins are not broken out of the logic board so it would be near impossible to implement this mod -- even if you were willing to open your new iPad and take a soldering iron to it!
扬声器比我们预期的要大:
在扬声器和其他组件上发现的连接器和MacBook Unibody笔记本电脑中常见的连接器一致。也就是说:iPad空间并不狭小。
双扬声器提供单声道声音。两个小的密封通道直接向三个音频端口,紧扣在iPad的底部边缘。当然,音频输出的是响亮的立体声。
You claim the two speakers are monophonic. Yet, in this review...
http://www.pcmag.com/article2/0,2817,236...
...the author claims that the speakers are delivering two channels:
"The small grille houses both a left and right speaker. Does this mean you will hear distinct stereo separation? No. The speakers are too close together for human ears to hear any separation, but the fact that there are two channels means no audio is lost, as is often the case when stereo mixes are played through mono speakers."
How do you respond?
My question is to know the speaker manufacturer.
I think Foster Electric Co., Ltd..
http://www.foster.co.jp/en_products/micr...
Is it the part of this manufacturer?
那个庞然大物是电池:重达148g。
在昨天证实了我们的怀疑,电池集成了两个独立的3.75V的锂聚合物电池,并且是如此大容量的电池。
电池标记:
P11GA6-01-C01F
741-00310A +
Ah, like the new iMacs, the Wi-Fi antenna is behind the Apple logo in the bottom case.
ivc로 부터 인용:
On the battery itself it states "Li-ion".
As stated on the black cover, it is a lithium-ion polymer battery.
iPad的电池比iPhone 3G电池要大得多。iPhone电池的容量约为iPad电池容量的五分之一。
第二张照片显示电池盖被剥离的画面,暴露了每个锂电池的保护和连接电路
第三张照片显示了电池板的另一侧,上面盖着有力的保护板。
You mention that the ipad has 2 3.7 volt li-poly batteries. Other wise know as li-po.
Li-po as I know it is still fairly unstable and if the voltage per cell drops to low it can cause damage to the cell.
I rac RC with li-po and have seen them catch on fire.
But looking at the pictures I beleive it's printed on the battery case as li-Ion.
Maybe a miss print in step 22? Maybe it should say Li-Ion?
Don't get me wrong, it will be a great day when Li-Po is more stable for electronics.
Ipad usage could be 20 hours insted of 10.
Scott
I stand corrected now that I have seen the full picture on a computer and not my phone.
I wonder how they are going to prevent the cells from dropping under 3 volt before they take on damage.
If you own one I would recommend never letting it die all the way. And keep about half charge on it if you are going to not use it for a while. These batteries are great but temperature affects them a lot.
Store at room temp. I would not leave it in your car on a hot summer day or a cold winter.
scott d로 부터 인용:
Don't worry about it. The control circuitry is extremely sophisticated and will not let it go too low or high. Besides, Li-Poly has been used in many consumer devices, including MacBooks (you won't believe me, but it's true), for years now.
裸露的后盖。苹果标志后面的天线看起来就像新的iMac上的天线
需要用金属撬棒将天线与后盖分开。
天线看起来很紧。检查一下那个凹槽只是为了让天线扣进去。
Jasiu로 부터 인용:
How much does the bottom case weigh ? Battery + glass + lcd is 494g. So it should be about 150g. Is it ?
I just weighed the aluminum back by itself. It's 138 grams, which is almost exactly 20% of the iPad's total weight.
Any idea what the scalloping on the back of the case is for? I mean, it looks pretty... is it due to the CNC machining process, or to more easily stabilise and lock the boards etc. into it, or..?
这是两个WiFi天线的细节图。这样密集的天线,无线接收应该是不错的。
将3G功能添加到一个WiFi版的iPad上,将不会是一个非常可行的升级。根据FCC发布的照片,3G模块包括额外的天线以及后面板上的塑料条都是为了改善接收效果。
Jeff로 부터 인용:
I haven't seen any mention of the microphone, but my assumption is that this is part of the headphone jack assembly (that small hole directly adjacent to the headphone jack).
Yes, the microphone is right next to the headphone jack, and the signal goes through the same ribbon cable as the headphone jack.
拆下一对螺丝,将耳机插孔拉出后盖。
和大多数便携设备一样,耳机插孔也很好地固定在后盖上。
麦克风就在耳机插孔旁边,通过与耳机插孔相同的触点进行连接。
CityZ로 부터 인용:
If Apple were more pro-consumer, they could engineer their products to be more water resistant. Instead, it almost seems as if some of their products (the notebooks) are designed to be damaged when spilled upon. A moisture barrier under the keyboard would've saved many headaches.
Nothing you've stated has anything whatsoever to do with "pro / anti consumer".
To the issue; unfortunately, barriers where you describe to keep moisture out; also keep heat in.
很密集吗?不,只有T4 Torx螺丝将每个标组件定在显示组件上。
幸运的是,Home键是一个带有自己的电路板的数字开关,使得更换更加容易。
It's nice to see the Home buttom can be easily repaired/replaced
Is that a space for an iSight camera?
Dudes, that sound hack could be sweet, IPAD BOOMBOXES ANYBODY?
POSTED BY IP
Ian P freely로 부터 인용:
POSTED BY IP
umm i am in!
拆卸显示器组件。
一条薄的带状电缆连接LED驱动板到LED背光上。
LED驱动电路和实际LCD和显示数据电缆连接器之间的相互连接都包含在同一个电路板中
Maybe that tape will prevent dust from entering... I sure hope it does.
It is gonna be awesome if there is also a teardown video~
jackwong64 - 답글
jackwong64로 부터 인용:
There should be a teatdown slideshow with funky music, but they never did a video before. it would be nice to see one though.
环境光传感器和照相机卡在一个小隔间里。
我们怀疑这个隔间是为环境光传感器设计的,而在这里安装摄像头的传言过于狂热。这个布局看起来非常类似于MacBook Pro 13“Unibody的摄像头的布局。
Dragan로 부터 인용:
Some phone uses VGA camera as light sensor. Is the same case?
No, a VGA camera would have a lens assembly and a different looking sensor. An ambient light sensor usually is just a LDR, a light dependent resistor which decreases its resistance the more light falls onto it. Or it is kind of a primitive solar cell which transfers the light to electric current detectable by the device.
Thomas J로 부터 인용:
I know how foto-sensitive elements works very well, but THIS particular sensor have more than two(three) output, as photo resistors/diodes or cells have.
Dragan로 부터 인용:
I know that resistors and diodes need only two pins. That also confused me a little bit before. But for 640 x 480 the sensor's aspect ratio isn't appropriate. And for a proper CCD or something similar there are too less pins. Even the very low-res IR-sensor in a wiimote is connected by 8 pins. Maybe its sort of a photodiode array.
Dragan로 부터 인용:
Resistors and diodes have two leads, but a lot of ambient light sensors have a built-in amplifier or analog-to-digital converter to make integration easier. For example, see the Toshiba TBS852. Even if the device doesn't have an amplifier, it's common on small packages to have extra leads whose only function is mechanical. But, since there is a capacitor next to this package, it probably has this extra circuitry.
Thomas J로 부터 인용:
Ok. At one moment, I thought that maybe it have serial bus or something, but it is too small. I think morcheeba is right.
Miner로 부터 인용:
I heard through a friend that the ambient light sensor is from a company in Texas....didn't say the name. Does anyone know if this is correct?
He might be thinking of Taos. I've worked with their color and light sensors before, and the pictures do look like their product. But then again, a 6-pin SOIC encased in in optical epoxy could be any company.
Tom로 부터 인용:
TAOS is probably a good bet. There's probably a way to tell if its theirs if iFixit could get a high res shot of the sensor. I went to TAOS' web site and they have a famiy of digital ambient light sensors that use dual photodiodes that are open so that light can reach them.
显示器似乎是粘在它的周围,但仍然可以从塑料框架中移除
显示组件的重量为:
液晶屏153克
前置玻璃193g
玻璃面板看起来很厚(约1.18毫米),考虑到iPad的尺寸,这并不是个大惊喜。相比之下,iPhone的价格约为1.02毫米。
Are y'all able to determine if the glass is regular glass or something like Dow Corning's gorilla glass? i.e how breakable is it?
把贴纸揭下来,在LCD底部可以看到更多的零件号。
数字编号:
A01327200 EP001A
10 1 25 S NE M213
我们不知道是谁制造了这个特殊的液晶显示器。你呢?我们拆解的另一个iPad是由LG制造的液晶面板。
I visited Toshiba Matshushita Display plant 18 months ago and there was some dinner and drinks discussion that they were working on a new larger display for the I pod touch. Maybe this was it?
Paul Flynn - 답글
The numbers read:
A01327200 EP001A
10 1 25 S NE M213
We don't know who made this particular LCD. Do you? Another iPad we opened contained a LCD panel that was manufactured by LG.
According to the model type "EP001A", I wonder if it is made by former EPSON imaging device, now that company has been sold to SONY Mobile Display Co.
At the same time, IPS technology patent of Hitachi is not licensed others except for its subsidiaries, CMO and LG, AFAIK.
is it possible to use this display on a raspberry pi zero w it has hdmi output
rich
和往常一样,最后的布局。
以下是重量分类:铝背:138克,电池:148克,LCD: 153克,玻璃(和框架):193克,扬声器:17克,主板:21克,其他所有:27克。
总计:697克(比苹果报的0.68公斤略重,还有其他人称他们的iPad吗?)
这可能是一部分,但我们将继续深入挖掘它的芯片。跟随@ifixit获取最新的更新!
Wait, no moving parts? Can't wait to find out this thing's achilles heel.
Travis Funk로 부터 인용:
The moving parts are the various buttons and the no-tilt slide switch. The Achilles' heel will be the small amount of RAM and limited flash storage space. The 2nd gen will most likely address the latter (just by increasing it), and possibly the former.
mars478로 부터 인용:
Does it still work? Hopefully it does!
umm... figga zup ngg trrflmap ebb zugor nyp. Uzzy marp downeb xrk. Wub funzl?
Do you have the weights for the component pieces in the step 31 photo? In particular how much does the aluminium back piece, the batteries and the screen each weigh compared to the total weight?
Trevor Abbott로 부터 인용:
I added the weights to the step. On my scale, the total weight of the iPad came out to 697 grams. That's definitely more than the .68 kg quoted in the Apple specs.
Any chance you guys did a wallpaper shot after removing the screen? Please tell me you did.
sp33dwagon - 답글
Luke Soules로 부터 인용:
Yes but if you go to http://www.apple.com/ipad/specs/ and go to footnote number 1 it reads, Actual size and weight vary by configuration and manufacturing process.
CityZ로 부터 인용:
Achilles' heel to me is like the DC cables on the first Aluminum iMac, or the bad capacitors in the iMac G5, or the top cases on plastic MacBooks, or the liquid cooling system on PowerMac G5s, or the DC-in boards on MacBook Unibody, or headphone jacks on iPod Video 5th gen, or yellow LCDs on the 27" iMac, etc. - not a lack of features.
There always seems to be some problem that has to get fixed on hundreds of these things. As a repairman, this is where the opportunity is. I think it will be just the headphone jack and the glass/LCD but one can always hope...maybe the batteries will swell up if the cells drop below 3V?
opie로 부터 인용:
No moving parts, but what makes the clicking noise when you wake the ipad up or put it to sleep. Sounds like heads being parked, but that can't be the case with solid state drives.
Speaker?
opie로 부터 인용:
Sure enough! Weird that Apple chose such a sound to coincide with waking/sleeping.
I haven't heard it, but 'clicking sound on sleep/wake' sounds more like bad design of the audio DtoA & amp, so that glitching sounds during circuitry power on/off switching and software initialization make it through to the speakers.
This is the sort of screwup you'd expect in a $20 MP3 player, not an Apple iWhatever.
TerraHertz - 답글
No, I'm pretty darn sure that the click is on purpose. Its there on every single iDevice. Have you ever used one? :)
Jaol -
TerraHertz로 부터 인용:
its a intentional feature apple put in the device, all iPhone os devices do it, its to let the user know that the device is off or on, people like that sort of confrimation
다음 번역가들에게 특별히 감사 드립니다:
74%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 8개
i used your post here -http://cafe.naver.com/disassemblemachine problem is hyunil0327@naver.com
Is it possible to replace the A4 with a better processor or add RAM?
No, it is not possible. You cannot upgrade any parts on this, or later generation iPads, since the boards are all completely custom designed for each generation, and not compatible. Also as in most laptops, the size constraints mean that the processor was not intended to be replaceable, as is clear when you look at step 15.
joshadow -
can I change the logic board?
Yes, you can. The system memory will be entirely different, though. iPad Wi-Fi Logic Board Replacement
Thanks for useful article.
Hello thank you for this. Please i want to have Schematic Diagram of this IPad please. I want to jump the connector on the bord. Thank you so much. My mail is Chekaraokoinin@gmail.com
Congratulations!!!
I Love the iFixit!!! It's is always a pleasure to follow the site!!!
Ok, so I presume there is a lot of free sapce to make some mookup's in the iPad as like as to "add" a full USB connector and also a SD Card or MicroSD card connector.
So, is there any body available to please us with a "How To"???
Would be nice!!!
Best regards
Paulo Magrani
Vrumm - 답글
I tried the iPad today. It seems that the Wi-fi signal reception on iPad is a lot weaker than that of an iPhone. Do you have any explanations? Does this mean iPad has a subpar antenna installed?
xana - 답글
Apple confirms iPad Wi-Fi issues.
Joe Smith - 답글
It must to check RF test for Wi-Fi capability and update driver first,then review the antena design.
Karo Lin - 답글
Is it an iPhone but bigger?
Traiva - 답글
There's enough space to shove in a 160GB iPod hard disk!
That plus the SSD, you'll have enough space for tons of everything!
rootbrian2000 - 답글
very very wondurful to see this tear down
ramsoft86 - 답글
How can you open the case without leaving a mark? I tried with a very, very thing screwdriver and it left a tiny but noticeable mark on the silver casing
Jim - 답글
