소개
Eine Daunenjacke bietet bei vielen Wetterbedingungen ein tolles Verhältnis von Wärme zu Gewicht. Aufgrund ihrer Vielseitigkeit werden Daunenjacken vielen Belastungen ausgesetzt: vom Alltag mit seinen vielzähligen Erledigungen bis hin zu mehrtägigen Bergtouren. In dieser Anleitung werden die Schritte erklärt, die erforderlich sind, um an das Innere einer Patagonia®-Daunenjacke heranzukommen, wenn Ausbesserungen vorgenommen werden sollen. Es gibt verschiedene Patagonia®-Daunenjacken, und jede ist etwas anders aufgebaut. Gehe also langsam vor, um die Jacke nicht dauerhaft zu beschädigen.
필요한 것
Reißverschluss der Patagonia®-Jacke öffnen.
Um die Jacke wieder zusammenzusetzen, diese Anleitung in umgekehrter Reihenfolge befolgen.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 3개
Does this have to be hand sewn back up? Is it just the basic handsewing stitch? It feel like the sewing up of the garment is just as challenging if not more than the seam-ripping of it. From this guide, I'm not at all confident about how to put my coat back together again - which has me be very wary of ripping the seams to take it apart. Please help! Thanks!
Great question Byron! You can either hand-sew or machine stitch your jacket back together. If you hand sew, you'll want to use a straight stitch (guide here: Sew a Straight Stitch). If you machine sew, be sure to use a very sharp needle in your machine. You will also probably want to use some sewing clips (like these: https://www.amazon.com/Clover-Wonder-Cli...) to hold the garment together while you sew it up, instead of pins that will create more little holes. In either case, take your time, as the material is very slippery. You will also want to follow the guide backwards to ensure you have the layers in the right positions and order. Good luck on your repair—you got this!
👏 Great guide on accessing the insides of a Patagonia down jacket! The step-by-step instructions are clear and helpful. For those worried about reassembly, hand-sewing or machine stitching with a sharp needle should do the trick. Remember to take your time and use sewing clips instead of pins. Happy repairing! 🧵🧥
