주요 콘텐츠로 건너뛰기
Wii Balance Board Battery Case Replacement
필요한 것
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: 1 단계, 이미지 1개 중 1개
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: 2 단계, 이미지 1개 중 1개
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: 3 단계, 이미지 1개 중 1개
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: 4 단계, 이미지 1개 중 1개
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: 5 단계, 이미지 1개 중 1개
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: 6 단계, 이미지 1개 중 1개
    • Lift off the gray back cover.
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: 7 단계, 이미지 2개 중 1개 Wii Balance Board Battery Case Replacement, Battery Compartment: 7 단계, 이미지 2개 중 2개
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: 8 단계, 이미지 1개 중 1개
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Michelle Reed
회원 가입일: 09/29/14
515 평판
안내서 1개를 작성함
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014 회원
CPSU-FORTE-F14S13G8
5 회원들
안내서 16개를 작성함
14가이드 댓글
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - 답글
Then what do you do after you remove the battery case?
CRAIG WIKMAN - 답글
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - 답글
u rock - it totally worked
scottydecept - 답글
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 65
지난 30일: 208
전체 시간: 46,450
