주요 콘텐츠로 건너뛰기
Wii Nunchuk Joystick and Button Replacement
필요한 것
  1. Wii Nunchuk Joystick and Button Replacement, Joystick and Button: 1 단계, 이미지 2개 중 1개 Wii Nunchuk Joystick and Button Replacement, Joystick and Button: 1 단계, 이미지 2개 중 2개
    • Use a Tri-point Y0 screwdriver to remove the two 9.2 mm screws from the back of the controller.
  2. Wii Nunchuk Joystick and Button Replacement: 2 단계, 이미지 3개 중 1개 Wii Nunchuk Joystick and Button Replacement: 2 단계, 이미지 3개 중 2개 Wii Nunchuk Joystick and Button Replacement: 2 단계, 이미지 3개 중 3개
    • Use a spudger or your hands to separate the top case of the Wii Nunchuk.
    • To remove it you will need to apply pressure at the top of the device near the joysick first. Once you apply pressure, gently pry apart the controller.
  3. Wii Nunchuk Joystick and Button Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the joystick off the attachment on the motherboard.
    • This will also expose the gyroscopic mechanism and allow you to clean off any debris that could be causing issues. Use a lint free cloth and isopropyl alcohol to clean the area. Make sure to let it dry before you reassemble the device.
  4. Wii Nunchuk Joystick and Button Replacement: 4 단계, 이미지 2개 중 1개 Wii Nunchuk Joystick and Button Replacement: 4 단계, 이미지 2개 중 2개
    • Take the motherboard by the edges, and gently lift it out of the shell, exposing the buttons.
  5. Wii Nunchuk Joystick and Button Replacement: 5 단계, 이미지 3개 중 1개 Wii Nunchuk Joystick and Button Replacement: 5 단계, 이미지 3개 중 2개 Wii Nunchuk Joystick and Button Replacement: 5 단계, 이미지 3개 중 3개
    • Set the motherboard to the side so that it is out of the way.
    • Push the buttons in from the outside of the device to pop them out.
    • Set the new buttons into the cutouts of the controller shell, ensuring they sit flush inside the controller.
  6. Wii Nunchuk Joystick and Button Replacement: 6 단계, 이미지 2개 중 1개 Wii Nunchuk Joystick and Button Replacement: 6 단계, 이미지 2개 중 2개
    • Set the motherboard back inside the center of the shell.
    • Ensure that the motherboard is flush inside of the controller.
  7. Wii Nunchuk Joystick and Button Replacement: 7 단계, 이미지 3개 중 1개 Wii Nunchuk Joystick and Button Replacement: 7 단계, 이미지 3개 중 2개 Wii Nunchuk Joystick and Button Replacement: 7 단계, 이미지 3개 중 3개
    • Push the new joystick onto the white attachment on the motherboard.
    • Make sure that the notch on the joystick and the notch on the attachment point line up to ensure a secure fit. The joystick may not attach if the notches are not aligned.
  8. Wii Nunchuk Joystick and Button Replacement: 8 단계, 이미지 2개 중 1개 Wii Nunchuk Joystick and Button Replacement: 8 단계, 이미지 2개 중 2개
    • Place the top case of the controller on the bottom shell, making sure to align the halves properly.
    • Push them together until you hear a small click, ensuring the controller is assembled securely.
  9. Wii Nunchuk Joystick and Button Replacement: 9 단계, 이미지 3개 중 1개 Wii Nunchuk Joystick and Button Replacement: 9 단계, 이미지 3개 중 2개 Wii Nunchuk Joystick and Button Replacement: 9 단계, 이미지 3개 중 3개
    • Use a Tri-point Y0 screwdriver to replace the two 9.2 mm screws that secure the back case.
  10. Wii Nunchuk Joystick and Button Replacement: 10 단계, 이미지 1개 중 1개
    • This replacement is now complete.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
George Barrone
회원 가입일: 03/05/24
205 평판
안내서 1개를 작성함
CSU Los Angeles, Team 8-9, Grodsky Spring 2024 CSU Los Angeles, Team 8-9, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S8G9
2 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 142
전체 시간: 2,202
