소개
Use this guide to replace the back panel on your Nintendo Wii U GamePad.
필요한 것
Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
Lift up and remove the battery cover.
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
Lift up the back plate.
거의 끝나갑니다!
결론
다른 11명이 해당 안내서를 완성하였습니다.
댓글 2개
and the front?
