주요 콘텐츠로 건너뛰기
Wii U GamePad Battery Replacement
필요한 것
  1. Wii U GamePad Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Wii U GamePad Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Battery Replacement: 2 단계, 이미지 3개 중 1개 Wii U GamePad Battery Replacement: 2 단계, 이미지 3개 중 2개 Wii U GamePad Battery Replacement: 2 단계, 이미지 3개 중 3개
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
결론
다른 29명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kim Arre
회원 가입일: 01/11/13
5,460 평판
안내서 8개를 작성함
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 41개를 작성함
8가이드 댓글
I only see two pins on most 3rd party rechargeable Li-Ion batteries. What is the pinout for the factory supplied battery? I would like to replace the battery with a similar 3.7v Li-Ion battery from somewhere like adafruit.
roof tip - 답글
I found an answer to my first question. My follow up question is if you can use a battery with only two charging pins and not the temp sensor pins?
roof tip - 답글
There's no reason you can't but without the temp sensor you must be cautions if your battery does over heat because it can lead to damages on the touchscreen as well.
Steven Chiu - 답글
Why does Nintendo mention a size #0 screwdriver while iFixit says #00?
proof: http://en-americas-support.nintendo.com/...
"•Use a crosshead style, size #0 screwdriver to avoid damage to the screw or threads"
"2.Loosen the battery cover screws with a crosshead style, size #0 screwdriver."
/a confused person
Chris - 답글
The size #00 is just a little smaller than the #0. When we wrote these guides, we used whatever worked for us. Either should work, but generally you should use the largest that will work to avoid stripping the screw.
Kim Arre -
댓글 쓰기
조회 통계:
지난 24시간: 34
지난 7일: 179
지난 30일: 555
전체 시간: 43,561
