주요 콘텐츠로 건너뛰기
Wii U GamePad LCD Display Replacement
필요한 것
동영상 개요
  1. Wii U GamePad LCD Display Replacement, Battery: 1 단계, 이미지 1/1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad LCD Display Replacement: 2 단계, 이미지 1/1
    • Lift and remove the battery plate.
  3. Wii U GamePad LCD Display Replacement: 3 단계, 이미지 1/3 Wii U GamePad LCD Display Replacement: 3 단계, 이미지 2/3 Wii U GamePad LCD Display Replacement: 3 단계, 이미지 3/3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad LCD Display Replacement, Outer Case: 4 단계, 이미지 1/3 Wii U GamePad LCD Display Replacement, Outer Case: 4 단계, 이미지 2/3 Wii U GamePad LCD Display Replacement, Outer Case: 4 단계, 이미지 3/3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad LCD Display Replacement: 5 단계, 이미지 1/1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
  6. Wii U GamePad LCD Display Replacement, Speakers: 6 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement, Speakers: 6 단계, 이미지 2/2
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Wii U GamePad LCD Display Replacement: 7 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 7 단계, 이미지 2/2
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  8. Wii U GamePad LCD Display Replacement, WiFi: 8 단계, 이미지 1/3 Wii U GamePad LCD Display Replacement, WiFi: 8 단계, 이미지 2/3 Wii U GamePad LCD Display Replacement, WiFi: 8 단계, 이미지 3/3
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  9. Wii U GamePad LCD Display Replacement: 9 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 9 단계, 이미지 2/2
    • With your fingers, lift and remove WiFi board.
    • Remove the board carefully as there are still two wires attached.
  10. Wii U GamePad LCD Display Replacement: 10 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 10 단계, 이미지 2/2
    • Disconnect the black and white wires off of the back of the WiFi module.
  11. Wii U GamePad LCD Display Replacement: 11 단계, 이미지 1/1
    • Lift and remove the WiFi module.
  12. Wii U GamePad LCD Display Replacement, Motherboard: 12 단계, 이미지 1/1
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad LCD Display Replacement: 13 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 13 단계, 이미지 2/2
    • Remove the blue connector using tweezers.
  14. Wii U GamePad LCD Display Replacement: 14 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 14 단계, 이미지 2/2
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
  15. Wii U GamePad LCD Display Replacement: 15 단계, 이미지 1/1
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad LCD Display Replacement: 16 단계, 이미지 1/3 Wii U GamePad LCD Display Replacement: 16 단계, 이미지 2/3 Wii U GamePad LCD Display Replacement: 16 단계, 이미지 3/3
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad LCD Display Replacement: 17 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 17 단계, 이미지 2/2
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad LCD Display Replacement: 18 단계, 이미지 1/3 Wii U GamePad LCD Display Replacement: 18 단계, 이미지 2/3 Wii U GamePad LCD Display Replacement: 18 단계, 이미지 3/3
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
  19. Wii U GamePad LCD Display Replacement, LCD Display: 19 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement, LCD Display: 19 단계, 이미지 2/2
    • Remove the four 5.1mm screws using Phillips size #0 screwdriver.
    • Pull the white and black cables away from the display case.
  20. Wii U GamePad LCD Display Replacement: 20 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 20 단계, 이미지 2/2
    • Lift and remove the grey display case with your fingers.
  21. Wii U GamePad LCD Display Replacement: 21 단계, 이미지 1/2 Wii U GamePad LCD Display Replacement: 21 단계, 이미지 2/2
    • Gently with your fingers, press on the front of the display and it will lift up.
    • Remove the display with your fingers.
결론
다른 79명이 해당 안내서를 완성하였습니다.
Valentina Cerruty
회원 가입일: 02/10/16
3,345 평판
안내서 7개 작성하였습니다
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G6
4 회원들
안내서 40개 작성하였습니다
댓글 18개
was really perfect to repair my device. Thank you very much for this help
Bernd Dietrich - 답글
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Stacey Hoggard - 답글
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Terry Moenkhaus -
Very happy with your manual! I've fixed it.
Paulus 68 - 답글
Mine did not come with the touch screen either.
Edwin Kahn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 46
7일 전: 269
30일 전: 1,156
전체 시간: 87,226
