소개
This guide will help you to replace your motherboard. For this replacement, You will need the tool #PH0 and tweezers.
필요한 것
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
이 단계에 사용된 도구:Tweezers$4.99
Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
Remove the white flex cable with the tweezers.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
