주요 콘텐츠로 건너뛰기
Wii U GamePad Outer Case Replacement
필요한 것
  1. Wii U GamePad Outer Case Replacement, Battery: 1 단계, 이미지 1/2 Wii U GamePad Outer Case Replacement, Battery: 1 단계, 이미지 2/2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: 2 단계, 이미지 1/3 Wii U GamePad Outer Case Replacement: 2 단계, 이미지 2/3 Wii U GamePad Outer Case Replacement: 2 단계, 이미지 3/3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: 3 단계, 이미지 1/3 Wii U GamePad Outer Case Replacement, Outer Case: 3 단계, 이미지 2/3 Wii U GamePad Outer Case Replacement, Outer Case: 3 단계, 이미지 3/3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: 4 단계, 이미지 1/2 Wii U GamePad Outer Case Replacement: 4 단계, 이미지 2/2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Kim Arre
회원 가입일: 01/11/13
4,918 평판
안내서 8개 작성하였습니다
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 38개 작성하였습니다
댓글 2개
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 115
전체 시간: 14,588
