소개
Use this guide to replace the outer case on your Nintendo Wii U GamePad.
  1. Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover. Lift up and remove the battery cover.
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it. Pull upwards from the bottom of the battery to release it. Pull upwards from the bottom of the battery to release it.
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers. Lift up the back plate. The back plate is still connected by a cable to the motherboard.
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
    how do i replace the whole front and back casing?
    enbodylin - 답글
  5. Unplug the connector that connects the back plate to the motherboard. Remove the back plate.
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
    You don't have to remove just be careful
    Heather Sheppard - 답글
    I tried to remove like at least 6 times but I wasn’t able to. Using tweezer, my nails, long nose pliers. There could be a lock but I gave up since I’m afraid if I put more force I might accidentally pull the wires. I’m able to remove the left and right analog stick with the back plate plugged, as mentioned, just be careful.
    Royce Remulla - 답글
결론
다른 8명이 해당 안내서를 완성하였습니다.
Kim Arre
회원 가입일: 2013년 01월 11일
3,366 평판
안내서 8개 작성하였습니다
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 19개 작성하였습니다
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 37
전체 시간: 9,574
