소개
This guide will help you to remove the outer case and be able to open the Nintendo Wii U Gamepad. You will need a Tri-WIng Y1 screw driver.
필요한 것
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
