주요 콘텐츠로 건너뛰기
Wii U GamePad Outer Case Replacement
필요한 것
  1. Wii U GamePad Outer Case Replacement, Battery: 1 단계, 이미지 1/1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Outer Case Replacement: 2 단계, 이미지 1/1
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: 3 단계, 이미지 1/3 Wii U GamePad Outer Case Replacement: 3 단계, 이미지 2/3 Wii U GamePad Outer Case Replacement: 3 단계, 이미지 3/3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Outer Case Replacement, Outer Case: 4 단계, 이미지 1/3 Wii U GamePad Outer Case Replacement, Outer Case: 4 단계, 이미지 2/3 Wii U GamePad Outer Case Replacement, Outer Case: 4 단계, 이미지 3/3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Outer Case Replacement: 5 단계, 이미지 1/1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Valentina Cerruty
회원 가입일: 02/10/16
3,345 평판
안내서 7개 작성하였습니다
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G6
4 회원들
안내서 40개 작성하였습니다
댓글 2개
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - 답글
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 32
30일 전: 173
전체 시간: 6,476
