주요 콘텐츠로 건너뛰기
Wii U GamePad Speakers Replacement
필요한 것
  1. Wii U GamePad Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Speakers Replacement: 2 단계, 이미지 1/1
    • Lift and remove the battery plate.
  3. Wii U GamePad Speakers Replacement: 3 단계, 이미지 1/3 Wii U GamePad Speakers Replacement: 3 단계, 이미지 2/3 Wii U GamePad Speakers Replacement: 3 단계, 이미지 3/3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Speakers Replacement, Outer Case: 4 단계, 이미지 1/3 Wii U GamePad Speakers Replacement, Outer Case: 4 단계, 이미지 2/3 Wii U GamePad Speakers Replacement, Outer Case: 4 단계, 이미지 3/3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Speakers Replacement: 5 단계, 이미지 1/1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
  6. Wii U GamePad Speakers Replacement, Speakers: 6 단계, 이미지 1/2 Wii U GamePad Speakers Replacement, Speakers: 6 단계, 이미지 2/2
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Wii U GamePad Speakers Replacement: 7 단계, 이미지 1/2 Wii U GamePad Speakers Replacement: 7 단계, 이미지 2/2
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Valentina Cerruty
회원 가입일: 02/10/16
3,345 평판
안내서 7개 작성하였습니다
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G6
4 회원들
안내서 40개 작성하였습니다
댓글 한 개
Awesome guide, replacement speakers worked flawlessly!!
Christopher Harris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 57
전체 시간: 4,381
