주요 콘텐츠로 건너뛰기
Wiko Getaway Screen Panel Replacement
필요한 것
동영상 개요
  1. Wiko Getaway Screen Panel Replacement, Back cover: 1 단계, 이미지 1/3 Wiko Getaway Screen Panel Replacement, Back cover: 1 단계, 이미지 2/3 Wiko Getaway Screen Panel Replacement, Back cover: 1 단계, 이미지 3/3
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: 2 단계, 이미지 1/3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: 2 단계, 이미지 2/3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: 2 단계, 이미지 3/3
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: 3 단계, 이미지 1/3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: 3 단계, 이미지 2/3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: 3 단계, 이미지 3/3
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: 4 단계, 이미지 1/3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: 4 단계, 이미지 2/3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: 4 단계, 이미지 3/3
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: 5 단계, 이미지 1/3 Wiko Getaway Screen Panel Replacement, Final: 5 단계, 이미지 2/3 Wiko Getaway Screen Panel Replacement, Final: 5 단계, 이미지 3/3
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alexandre Isaac
회원 가입일: 04/07/13
2,863 평판
안내서 8개 작성하였습니다
The Repair Academy The Repair Academy 회원
Business
1 회원
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 2,080
