주요 콘텐츠로 건너뛰기
Windsor Willow Chain Replacement
  1. Windsor Willow Chain Replacement, Chain: 1 단계, 이미지 1개 중 1개
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Chain Replacement: 2 단계, 이미지 1개 중 1개
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Chain Replacement: 3 단계, 이미지 2개 중 1개 Windsor Willow Chain Replacement: 3 단계, 이미지 2개 중 2개
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Chain Replacement: 4 단계, 이미지 1개 중 1개
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Stuart Ross
회원 가입일: 01/24/17
225 평판
안내서 2개를 작성함
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G6
5 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 87
