주요 콘텐츠로 건너뛰기
Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement
필요한 것
  1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 3/3
    • Remove the air intake cover by placing your hands at the top of the air intake cover and gently pulling away from the device.
    • You can choose to unplug or leave the device plugged in. Either way, it will not affect the process.
  2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 2 단계, 이미지 1/2 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 2 단계, 이미지 2/2
    • Using your vacuum, clean the air intake screen.
    • Any vacuum and any attachment that has a brush will work for cleaning the air intake screen.
  3. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 3 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 3 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 3 단계, 이미지 3/3
    • Detach the air intake screen by placing your fingers on the top two hinges.
    • Gently press the two hinges down and pull away from the device.
    • Using your vacuum, clean the other side of the air intake screen.
  4. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 4 단계, 이미지 1/2 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 4 단계, 이미지 2/2
    • Remove the Activated Carbon Pre-Filter by pulling it away from the device.
    • Throw away the Activated Carbon Pre-Filter into a garbage can.
  5. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 5 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 5 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 5 단계, 이미지 3/3
    • Remove the True HEPA Filter by pulling it away from the device.
    • Throw away the True HEPA Filter into a garbage can.
  6. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 6 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 6 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 6 단계, 이미지 3/3
    • Replace the True HEPA Filter by inserting it into the empty space in the device.
    • The arrow on the top of the True HEPA Filter should point towards the device and away from you.
  7. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 7 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 7 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 7 단계, 이미지 3/3
    • Replace the Activated Carbon Pre-Filter by inserting it into the space in front of the True HEPA Filter.
  8. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 8 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 8 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 8 단계, 이미지 3/3
    • Attach the air intake screen by placing the bottom two hinges in the bottom two holes of the device.
    • Using your fingers, gently press down on the top two hinges while placing them in the top two holes of the device.
  9. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 9 단계, 이미지 1/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 9 단계, 이미지 2/3 Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: 9 단계, 이미지 3/3
    • Attach the air intake cover by gently pressing the top of the cover against the device.
결론
You have now replaced the HEPA Filter to continue purifying the air.
다른 7명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 09/26/18
379 평판
안내서 1개 작성함
댓글 5개
Very easy to replace. Breeze.
Alex Parson - 답글
@tackerman Where can I get a replacement air intake screen (the mesh ‘Pre-Filter’?) Mine has a tear in it and I can't find a replacement anywhere online. Thanks!
Aftab Khan - 답글
You can just scotch tape the tear (from two sides) if it is not too big
Anwar Ben Tanfous -
My Winix C535 came with two air filters. This video should only shows one. So is it supposed to have two filters inserted?
Ray Hill - 답글
No, it's likely yours came with an extra replacement filter with the purchase. Their should only be one HEPA filter followed by one carbon filter and then lastly the mesh pre filter screen that locks into place.
JASON UNDERWOOD -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 29
30일 전: 118
전체 시간: 13,396
