주요 콘텐츠로 건너뛰기
Wintec Filemate Clear 7" Charging Pin Replacement
  1. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Backplate: 1 단계, 이미지 1/1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Charging Pin Replacement: 2 단계, 이미지 1/2 Wintec Filemate Clear 7" Charging Pin Replacement: 2 단계, 이미지 2/2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Battery: 3 단계, 이미지 1/1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Charging Pin Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Charging Pin Replacement: 5 단계, 이미지 1/1
    • Fully remove the battery from the device.
  6. 주의: 6-10 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Wintec Filemate Clear 7" Charging Pin Replacement, Motherboard: 6 단계, 이미지 1/1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: 7 단계, 이미지 1/3 Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: 7 단계, 이미지 2/3 Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: 7 단계, 이미지 3/3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Charging Pin Replacement, Detach the Motherboard: 8 단계, 이미지 1/2 Wintec Filemate Clear 7" Charging Pin Replacement, Detach the Motherboard: 8 단계, 이미지 2/2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Charging Pin Replacement: 9 단계, 이미지 1/1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Charging Pin Replacement: 10 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • De-tatch the motherboard output wires from the screen using the tweezers.
  11. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Charging Pin: 11 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the charging pin holster.
    • Clamp on the end of the holster with the tweezers and twist until it becomes detached.
    • Repeat for the other side.
  12. Wintec Filemate Clear 7" Charging Pin Replacement: 12 단계, 이미지 1/1
    • Clamp onto the charging pin and twist up until it pops out of place.
결론
To reassemble your device, follow these instructions in reverse order. The charging pin holster needs to be soldered back into place.
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Ferraro
회원 가입일: 01/20/15
431 평판
안내서 6개 작성하였습니다
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014 회원
USFT-BLACKWELL-S14S19G6
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 129
