소개
To complete this guide, you will need to take apart the tablet almost completely.
필요한 것
Un-stick the battery from the motherboard assembly with the plastic opening tool.
6 단계 Motherboard
주의: 6-10 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Locate each of the motherboard's 4 mm screws.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
There are two additional 4 mm screws holding the front screen.
Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
댓글 한 개
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
