주요 콘텐츠로 건너뛰기
Wintec Filemate Clear 7" Motherboard Replacement
필요한 것
  1. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Backplate: 1 단계, 이미지 1/1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Motherboard Replacement: 2 단계, 이미지 1/2 Wintec Filemate Clear 7" Motherboard Replacement: 2 단계, 이미지 2/2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Battery: 3 단계, 이미지 1/1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Motherboard Replacement: 5 단계, 이미지 1/1
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: 7 단계, 이미지 1/3 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: 7 단계, 이미지 2/3 Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: 7 단계, 이미지 3/3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: 8 단계, 이미지 1/2 Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: 8 단계, 이미지 2/2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Motherboard Replacement: 9 단계, 이미지 1/1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Motherboard Replacement: 10 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • De-tatch the motherboard output wires from the screen using the tweezers.
결론
Nicholas Ferraro
회원 가입일: 01/20/15
431 평판
안내서 6개 작성하였습니다
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014 회원
USFT-BLACKWELL-S14S19G6
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 104
