주요 콘텐츠로 건너뛰기
Wire Stripping
필요한 것
  1. Wire Stripping, Wire Stripping: 1 단계, 이미지 1개 중 1개
    • Match your gauge of wire to the gauge on a wire stripper.
    • Some wire strippers will have two gauge sizes for the same hole, one for solid wire and one for stranded. Make sure you use the right one for the wire you are stripping!
  2. Wire Stripping: 2 단계, 이미지 1개 중 1개
    • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
    • You can strip more than 1/4" at a time, but the effort becomes harder. About 1/2-5/8" (13-16 mm) is the most you should probably attempt.
  3. Wire Stripping: 3 단계, 이미지 1개 중 1개
    • While squeezing, pull the stripper toward the end of the wire. This should expose some of the wire by removing its insulation.
결론
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
nat coll
회원 가입일: 09/27/12
790 평판
안내서 14개를 작성함
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 회원
CPSU-FORTE-F12S7G53
5 회원들
안내서 33개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 167
지난 30일: 462
전체 시간: 9,797
