이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Wire needs to be exposed from its insulation in order before it can be soldered to another wire. Wire stripping exposes the wire so you are able to make good connections.
필요한 것
거의 끝나갑니다!
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
결론
다른 8명이 해당 안내서를 완성하였습니다.
