주요 콘텐츠로 건너뛰기
Wire Sunglasses Frame Lens Replacement
필요한 것
  1. Wire Sunglasses Frame Lens Replacement, Sunglasses Lens: 1 단계, 이미지 2개 중 1개 Wire Sunglasses Frame Lens Replacement, Sunglasses Lens: 1 단계, 이미지 2개 중 2개
    • Place the missing lens against the upper rim of the glasses, feel free to fit the bottom wire underneath.
  2. Wire Sunglasses Frame Lens Replacement: 2 단계, 이미지 2개 중 1개 Wire Sunglasses Frame Lens Replacement: 2 단계, 이미지 2개 중 2개
    • While holding the frame in position, thread the plastic strip around the metal wire. The strip should sit around halfway through it.
  3. Wire Sunglasses Frame Lens Replacement: 3 단계, 이미지 2개 중 1개 Wire Sunglasses Frame Lens Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic strip as an anchor, slowly re-fasten the wire underneath the bottom of the frame. Slide the strip from one end of the frame to the other.
    • The lens must remain firmly around the upper rim for the wire to slide underneath.
  4. Wire Sunglasses Frame Lens Replacement: 4 단계, 이미지 2개 중 1개 Wire Sunglasses Frame Lens Replacement: 4 단계, 이미지 2개 중 2개
    • Once the wire is under the frame, use the plastic strip to gently adjust the wire as needed.
  5. Wire Sunglasses Frame Lens Replacement: 5 단계, 이미지 2개 중 1개 Wire Sunglasses Frame Lens Replacement: 5 단계, 이미지 2개 중 2개
    • Once you are done, begin to remove the plastic strip from the frame.
    • Gently tug at one end of the strip to remove it from between the lens and the wire.
  6. Wire Sunglasses Frame Lens Replacement: 6 단계, 이미지 2개 중 1개 Wire Sunglasses Frame Lens Replacement: 6 단계, 이미지 2개 중 2개
    • Ensure the lens is secured by gently pushing it.
    • If the lens is still loose or needs to be re-adjusted, take the lens out and start again from Step 1.
결론
Following these steps will help save time and money so you can continue enjoying your shades.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Violet Lampman
회원 가입일: 02/08/24
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 243
