주요 콘텐츠로 건너뛰기
Wireless Xbox One Controller Bumper Assembly Replacement
필요한 것
  1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the battery cover from the back of the controller by sliding it upwards.
  2. Wireless Xbox One Controller Bumper Assembly Replacement: 2 단계, 이미지 3개 중 1개 Wireless Xbox One Controller Bumper Assembly Replacement: 2 단계, 이미지 3개 중 2개 Wireless Xbox One Controller Bumper Assembly Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Using the halberd spudger, pry the grip casing upwards from the handle.
    • Remove the grip casing from both the left and right handles of the controller.
    • It helps to begin near the top of the grip casing near the trigger.
  3. Wireless Xbox One Controller Bumper Assembly Replacement: 3 단계, 이미지 2개 중 1개 Wireless Xbox One Controller Bumper Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
    • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
  4. Wireless Xbox One Controller Bumper Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back of the controller casing by lifting it up and off.
  5. Wireless Xbox One Controller Bumper Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the internal assembly from the plastic controller case.
    • Handle gently; the motors on the bottom left and right are not firmly attached.
  6. Wireless Xbox One Controller Bumper Assembly Replacement: 6 단계, 이미지 2개 중 1개 Wireless Xbox One Controller Bumper Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
  7. Wireless Xbox One Controller Bumper Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
    • Gently follow the motion indicated by the arrows.
  8. Wireless Xbox One Controller Bumper Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Remove bumpers and replace by inserting a new bumper assembly.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Patrick Ashman
회원 가입일: 01/30/23
384 평판
안내서 1개를 작성함
Cal Poly, Team 2-2, Johann Winter 2023 Cal Poly, Team 2-2, Johann Winter 2023 회원
CPSU-JOHANN-W23S2G2
3 회원들
안내서 3개를 작성함
1가이드 댓글
hie my controller vibrate and goes off immediately I start using it kindly assist
Shakes makena - 답글
댓글 쓰기
조회 통계:
지난 24시간: 41
지난 7일: 130
지난 30일: 507
전체 시간: 14,185
