주요 콘텐츠로 건너뛰기
Withings Smart Body Analyzer Motherboard Replacement
필요한 것
  1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: 1 단계, 이미지 1/1
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Motherboard Replacement: 2 단계, 이미지 1/3 Withings Smart Body Analyzer Motherboard Replacement: 2 단계, 이미지 2/3 Withings Smart Body Analyzer Motherboard Replacement: 2 단계, 이미지 3/3
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Motherboard Replacement: 3 단계, 이미지 1/2 Withings Smart Body Analyzer Motherboard Replacement: 3 단계, 이미지 2/2
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
  5. Withings Smart Body Analyzer Motherboard Replacement: 5 단계, 이미지 1/1
    • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
  6. Withings Smart Body Analyzer Motherboard Replacement: 6 단계, 이미지 1/1
    • Once the two screws and the ribbon cable are detached, remove the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ashley Dauphinee
회원 가입일: 03/22/17
317 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G1, Julie Spring 2017 UMass Dartmouth, Team S4-G1, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G1
4 회원들
안내서 4개 작성하였습니다
댓글 2개
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - 답글
where do you get the motherboard?
cost?
donald taylor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 40
전체 시간: 4,892
