주요 콘텐츠로 건너뛰기
Wolf Gourmet WGBL100S Control Board Replacement
필요한 것
  1. Wolf Gourmet WGBL100S Control Board Replacement, Control Board: 1 단계, 이미지 1/2 Wolf Gourmet WGBL100S Control Board Replacement, Control Board: 1 단계, 이미지 2/2
    • Flip the base of the blender upside-down.
    • Remove the four 1/2" long screws in the corners of the base using a Phillips #2 screwdriver.
  2. Wolf Gourmet WGBL100S Control Board Replacement: 2 단계, 이미지 1/2 Wolf Gourmet WGBL100S Control Board Replacement: 2 단계, 이미지 2/2
    • Using the metal spudger, pry off one half of each rubber foot.
    • Note that one side of the foot is glued down; pry off the other side.
  3. Wolf Gourmet WGBL100S Control Board Replacement: 3 단계, 이미지 1/1
    • Using the same screwdriver, remove the next four 1/2" long screws in the holes under the feet.
    • Pull the base off of the blender.
  4. Wolf Gourmet WGBL100S Control Board Replacement: 4 단계, 이미지 1/2 Wolf Gourmet WGBL100S Control Board Replacement: 4 단계, 이미지 2/2
    • Pull off the plastic housing.
  5. Wolf Gourmet WGBL100S Control Board Replacement: 5 단계, 이미지 1/2 Wolf Gourmet WGBL100S Control Board Replacement: 5 단계, 이미지 2/2
    • Using the same Phillips #2 screwdriver, remove the two 3/4" long screws holding the control board in place.
  6. Wolf Gourmet WGBL100S Control Board Replacement: 6 단계, 이미지 1/2 Wolf Gourmet WGBL100S Control Board Replacement: 6 단계, 이미지 2/2
    • Using pliers, pull off all the connectors on the top.
  7. Wolf Gourmet WGBL100S Control Board Replacement: 7 단계, 이미지 1/1
    • Pull or pry off the last connector block, then remove the control board.
결론
Cole Gillespie
회원 가입일: 04/19/18
476 평판
안내서 2개 작성하였습니다
Cal Poly, Team S25-G16, Maness Spring 2018 Cal Poly, Team S25-G16, Maness Spring 2018 회원
CPSU-MANESS-S18S25G16
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 337
