주요 콘텐츠로 건너뛰기
Wolf Gourmet WGBL100S O-ring Replacement
필요한 것
  1. Wolf Gourmet WGBL100S O-ring Replacement, Blender Blades: 1 단계, 이미지 1/1
    • Flip over the pitcher to expose the base of the blade assembly.
    • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
    • Apply a solvent to remove adhesive if necessary.
  2. Wolf Gourmet WGBL100S O-ring Replacement: 2 단계, 이미지 1/1
    • Using a pair of pliers, pull of the drive shaft coupling.
  3. Wolf Gourmet WGBL100S O-ring Replacement: 3 단계, 이미지 1/2 Wolf Gourmet WGBL100S O-ring Replacement: 3 단계, 이미지 2/2
    • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
  4. Wolf Gourmet WGBL100S O-ring Replacement: 4 단계, 이미지 1/1
    • Remove the nut using a crescent wrench.
  5. Wolf Gourmet WGBL100S O-ring Replacement: 5 단계, 이미지 1/1
    • Push the blade assembly into the jar.
    • Remove the blades from the device.
    • Be careful not to cut yourself when handling the blades.
  6. Wolf Gourmet WGBL100S O-ring Replacement, O-Ring: 6 단계, 이미지 1/2 Wolf Gourmet WGBL100S O-ring Replacement, O-Ring: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to pull off the o-ring.
    • Be careful not to cut yourself while handling the blender blades.
결론
Luke Kutz
회원 가입일: 04/19/18
354 평판
안내서 3개 작성하였습니다
Cal Poly, Team S25-G16, Maness Spring 2018 Cal Poly, Team S25-G16, Maness Spring 2018 회원
CPSU-MANESS-S18S25G16
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 10
전체 시간: 280
