주요 콘텐츠로 건너뛰기
Wolf Gourmet WGBL100S Power Cord Replacement
필요한 것
  1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
    • Ensure the blender is off and unplugged before starting.
  2. Wolf Gourmet WGBL100S Power Cord Replacement: 2 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement: 2 단계, 이미지 2/2
    • Using a metal spudger, pry up one side of each of the rubber feet.
    • Note that one side of each foot is glued down; pry up the non-glued side.
  3. Wolf Gourmet WGBL100S Power Cord Replacement: 3 단계, 이미지 1/1
    • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
  4. Wolf Gourmet WGBL100S Power Cord Replacement: 4 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement: 4 단계, 이미지 2/2
    • Pull off the base and remove the plastic housing underneath.
  5. Wolf Gourmet WGBL100S Power Cord Replacement: 5 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement: 5 단계, 이미지 2/2
    • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
    • Pull the plastic cover off.
  6. Wolf Gourmet WGBL100S Power Cord Replacement: 6 단계, 이미지 1/1
    • Using a wire cutter, cut the three wires of the power cord.
  7. Wolf Gourmet WGBL100S Power Cord Replacement: 7 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement: 7 단계, 이미지 2/2
    • Pull the cut power cord through the base.
    • Then thread the replacement cord back through and re-attach the plastic cover.
  8. Wolf Gourmet WGBL100S Power Cord Replacement: 8 단계, 이미지 1/3 Wolf Gourmet WGBL100S Power Cord Replacement: 8 단계, 이미지 2/3 Wolf Gourmet WGBL100S Power Cord Replacement: 8 단계, 이미지 3/3
    • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
    • Twist each strand of wires together to keep them neat.
  9. Wolf Gourmet WGBL100S Power Cord Replacement: 9 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement: 9 단계, 이미지 2/2
    • Twist together the wires from the replacement cord to the wires still attached to the blender.
    • Solder the connection if possible.
  10. Wolf Gourmet WGBL100S Power Cord Replacement: 10 단계, 이미지 1/2 Wolf Gourmet WGBL100S Power Cord Replacement: 10 단계, 이미지 2/2
    • Wrap all the connections in electrical tape or heat shrink tubing.
결론
To reassemble your device, follow steps 1-5 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Cole Gillespie
회원 가입일: 04/19/18
476 평판
안내서 2개 작성하였습니다
Cal Poly, Team S25-G16, Maness Spring 2018 Cal Poly, Team S25-G16, Maness Spring 2018 회원
CPSU-MANESS-S18S25G16
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 263
