주요 콘텐츠로 건너뛰기
Wolf Gourmet WGTR102S Lighting Component Replacement
필요한 것
  1. Wolf Gourmet WGTR102S Lighting Component Replacement, Outer Shell: 1 단계, 이미지 1/1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Lighting Component Replacement: 2 단계, 이미지 1/1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Lighting Component Replacement: 3 단계, 이미지 1/1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Lighting Component Replacement: 4 단계, 이미지 1/1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Lighting Component Replacement: 5 단계, 이미지 1/1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Lighting Component Replacement: 6 단계, 이미지 1/1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Lighting Component Replacement: 7 단계, 이미지 1/1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Lighting Component Replacement: 8 단계, 이미지 1/2 Wolf Gourmet WGTR102S Lighting Component Replacement: 8 단계, 이미지 2/2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Lighting Component Replacement, Lighting Component: 9 단계, 이미지 1/1
    • Remove two 8mm screws securing the lighting component using a Tri-point Y1 screwdriver.
  10. Wolf Gourmet WGTR102S Lighting Component Replacement: 10 단계, 이미지 1/1
    • Remove the lighting component from the device.
결론
Ryan Funchess
회원 가입일: 04/19/18
715 평판
안내서 5개 작성하였습니다
Cal Poly, Team S22-G5, Maness Spring 2018 Cal Poly, Team S22-G5, Maness Spring 2018 회원
CPSU-MANESS-S18S22G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hi, do you have an idea how to remove the beeping sound? It's annoying, I want to remove it
Thank you
francis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 257
