주요 콘텐츠로 건너뛰기
Wood Stool Leg Glide Replacement
필요한 것
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: 1 단계, 이미지 1/1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: 2 단계, 이미지 1/1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: 3 단계, 이미지 1/1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: 4 단계, 이미지 1/1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: 5 단계, 이미지 1/1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: 6 단계, 이미지 1/1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: 7 단계, 이미지 1/2 Wood Stool Leg Glide Replacement: 7 단계, 이미지 2/2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
결론
Molly Ristig
회원 가입일: 10/07/19
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 384
