소개
Occasionally the dryer air may be muffled or too hot due to a clogged filter, and so cleaning or replacement may be necessary. Disassembly of the device requires a special bit for removal of tamper-proof screws.
필요한 것
In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
Using the special bit, remove the large screws at the bottom of the casing.
To remove the case, lift the indicated spot with your hands.
거의 끝나갑니다!
결론
