주요 콘텐츠로 건너뛰기
World Dryer Airforce J4-973A3 Air Filter Replacement
필요한 것
  1. World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: 1 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: 1 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: 1 단계, 이미지 3/3
    • In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Air Filter Replacement: 2 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Air Filter Replacement: 2 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Air Filter Replacement: 2 단계, 이미지 3/3
    • To access both filters, unscrew all three 1/2" Ph2 screws.
    • Gently pull the plate away from the black, coarse filter.
  3. World Dryer Airforce J4-973A3 Air Filter Replacement: 3 단계, 이미지 1/2 World Dryer Airforce J4-973A3 Air Filter Replacement: 3 단계, 이미지 2/2
    • After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
    • We recommend either vacuuming the filters or washing them to remove the dust that has accumulated on the filter.
    • Leave the filters out to dry for 24 hours before putting it back into use, in order to avoid water damage or electric shock!
결론
Blane Hirsh
회원 가입일: 09/17/18
260 평판
안내서 2개 작성하였습니다
Washington State, Team S1-G6, Hope Fall 2018 Washington State, Team S1-G6, Hope Fall 2018 회원
WSU-HOPE-F18S1G6
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 240
