주요 콘텐츠로 건너뛰기
World Dryer Airforce J4-973A3 Motor Replacement
필요한 것
  1. World Dryer Airforce J4-973A3 Motor Replacement, Motor: 1 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: 1 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: 1 단계, 이미지 3/3
    • To change the motor, start by removing the metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Motor Replacement: 2 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement: 2 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement: 2 단계, 이미지 3/3
    • Remove the three 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the device.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a small prier.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Motor Replacement: 3 단계, 이미지 1/2 World Dryer Airforce J4-973A3 Motor Replacement: 3 단계, 이미지 2/2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Motor Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
  5. World Dryer Airforce J4-973A3 Motor Replacement: 5 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement: 5 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement: 5 단계, 이미지 3/3
    • Remove the brass nut from its bolt using a 10mm wrench.
    • Once the nut is free, disconnect the green wire.
  6. World Dryer Airforce J4-973A3 Motor Replacement: 6 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement: 6 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement: 6 단계, 이미지 3/3
    • Remove the rainbow ribbon cable using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  7. World Dryer Airforce J4-973A3 Motor Replacement: 7 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement: 7 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement: 7 단계, 이미지 3/3
    • Remove the four 3/4" Ph2 screws from the back of the device body.
    • Separate the motor housing from the device body.
    • Ensure that all wires connecting the motor housing and motherboard are disconnected before removing the component.
  8. World Dryer Airforce J4-973A3 Motor Replacement: 8 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement: 8 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement: 8 단계, 이미지 3/3
    • Remove the four 1/2" Ph2 screws from the filter.
    • Pull the filter plate away to reveal the motor.
  9. World Dryer Airforce J4-973A3 Motor Replacement: 9 단계, 이미지 1/3 World Dryer Airforce J4-973A3 Motor Replacement: 9 단계, 이미지 2/3 World Dryer Airforce J4-973A3 Motor Replacement: 9 단계, 이미지 3/3
    • Pull the motor out of the housing.
    • Be sure to feed the wires through the slot as you pull the motor out.
결론
Eli Forbes
회원 가입일: 09/17/18
172 평판
안내서 1개 작성함
Washington State, Team S1-G6, Hope Fall 2018 Washington State, Team S1-G6, Hope Fall 2018 회원
WSU-HOPE-F18S1G6
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 302
