소개
If the device does not start and the Sensor Lens is in good condition, then the Circuit Board may be faulty and need replacement.
  1. Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand. The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws. The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom. Lift the grey belt away. This gives access to the server board.
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove all three 1/2" Ph1 screws connecting the server board to the device. During reassembly, install the screws before reattaching the wires. During reassembly, install the screws before reattaching the wires.
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  5. Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board. Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires. After these steps, the server board should easily come off the side of the device.
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
결론
Blane Hirsh
회원 가입일: 2018년 09월 17일
255 평판
안내서 2개 작성하였습니다
Washington State, Team S1-G6, Hope Fall 2018 Washington State, Team S1-G6, Hope Fall 2018 회원
WSU-HOPE-F18S1G6
4 회원들
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 55
