주요 콘텐츠로 건너뛰기
WowWee CHiP Robot Dog Ear Replacement
필요한 것
  1. WowWee CHiP Robot Dog Ear Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Ear Replacement: 2 단계, 이미지 2개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 2 단계, 이미지 2개 중 2개
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Ear Replacement: 3 단계, 이미지 2개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 3 단계, 이미지 2개 중 2개
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Ear Replacement: 4 단계, 이미지 3개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 4 단계, 이미지 3개 중 2개 WowWee CHiP Robot Dog Ear Replacement: 4 단계, 이미지 3개 중 3개
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Ear Replacement, Ear: 5 단계, 이미지 2개 중 1개 WowWee CHiP Robot Dog Ear Replacement, Ear: 5 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips screws shown.
  6. WowWee CHiP Robot Dog Ear Replacement: 6 단계, 이미지 3개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 6 단계, 이미지 3개 중 2개 WowWee CHiP Robot Dog Ear Replacement: 6 단계, 이미지 3개 중 3개
    • Pull up top part of toy and remove the connecting wires.
    • Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
  7. WowWee CHiP Robot Dog Ear Replacement: 7 단계, 이미지 3개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 7 단계, 이미지 3개 중 2개 WowWee CHiP Robot Dog Ear Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 4 Phillips screws to separate the head from the body.
  8. WowWee CHiP Robot Dog Ear Replacement: 8 단계, 이미지 2개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
  9. WowWee CHiP Robot Dog Ear Replacement: 9 단계, 이미지 3개 중 1개 WowWee CHiP Robot Dog Ear Replacement: 9 단계, 이미지 3개 중 2개 WowWee CHiP Robot Dog Ear Replacement: 9 단계, 이미지 3개 중 3개
    • Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
결론
작성자
3다른 기여자 명과 함께
Joseph Dantes
회원 가입일: 10/02/18
514 평판
안내서 4개를 작성함
댓글 한 개
It’s almost a disassembly, probably quite hard to do. I did disassemble a MiPosaur, but some parts broke off. (!!!)
Michael Deitz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 18
전체 시간: 1,684
