주요 콘텐츠로 건너뛰기
WowWee CHiP Robot Dog Smart Watch Battery Replacement
필요한 것
  1. WowWee CHiP Robot Dog Smart Watch Battery Replacement, Smart Watch Battery: 1 단계, 이미지 1/2 WowWee CHiP Robot Dog Smart Watch Battery Replacement, Smart Watch Battery: 1 단계, 이미지 2/2
    • Place the Smart Watch on its back or side so that the full watch band is visible.
  2. WowWee CHiP Robot Dog Smart Watch Battery Replacement: 2 단계, 이미지 1/1
    • Remove the wrist strap by gently pulling the band off of the plastic pegs on the back of the watch.
  3. WowWee CHiP Robot Dog Smart Watch Battery Replacement: 3 단계, 이미지 1/1
    • Remove the four screws in the back of the watch using a Phillips #0 screwdriver.
  4. WowWee CHiP Robot Dog Smart Watch Battery Replacement: 4 단계, 이미지 1/1
    • Gently pull off the back side of the watch component.
  5. WowWee CHiP Robot Dog Smart Watch Battery Replacement: 5 단계, 이미지 1/1
    • Pull the battery and motherboard component out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joseph Dantes
회원 가입일: 10/02/18
514 평판
안내서 4개 작성하였습니다
댓글 4개
What batteries does the smart band use?
Yourmajesty100 - 답글
Can be replaced by one of these and some soldering.
https://www.adafruit.com/product/1317
Alto -
This doesn’t detail sourcing the replacement or un-soldering then soldering the battery.
This is just “WowWee CHiP Robot Dog Smart Watch Battery Inspection” Not Replacement.
Alto - 답글
But the discussion is under battery replacement
Daniel peters -
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 6
30일 전: 25
전체 시간: 3,430
